I cant get it still wont read the e85
if someone could fix this tune I would pay for your time
I got it to run using settings from 2017 f150
https://www.dropbox.com/sh/97e689wv0...nwWK71KVa?dl=0
I will leave this up for 24hrs. this is some of the parameters your were missing on your flex file.
how do I open it with hp turners or view it nothing I got on my computer will open it
in editor click on Edit> TEMPLATE APPLICATOR> Open File>Apply Changes > a box OPENS with a Green Arrow it>click it and it will apply the file
Thanks I will check it out
i used frpp3 as the base file for my 2016 gt with 350 tb,manifold headers with e85 .
where do I get that at
this is my log with the gt350tb installed still got some tq based decal coming on wot
Should be a copy in tune repository
what do you think about this wot logs is torque control supposed to take over spark source
Change the under flex fuel tab> GENERAL > NVM AFR RECOVERY > to Use Initial Value (this should help read for E-85)
Also MAF Peroid Still needs work, from looking at the 4th gear 5,000 rpm log file. Fix the Fuel trims
IPC Torque Monitors >raise wheel torque error say 75,000.00 ( helps with torque monitoring )
Max Torque Raise to 650
