What do I need to change in my tune to run a return fuel system on 2004 mustang 4.6
disable the adaptive pump update switch and set the pump output table to all 15s
then simply wire up the current fuel pump wires to the new fuel pump relay
done
Thank You
keep looking
Good morning here is what i have done for the return fuel system
under fuel system-fuel pump-desired voltage-(15.00) volts all cells. fuel system-feedback-P Gain,I Gain,D Gain set 0
under fuel system-Desired fuel pressure-Normal- will be set at 4lbs less than my fuel psi
