But will connect to scanner. Anyone have any ideas?
2002 Silverado 5.3
2002 Silverado 5.3
That's pretty vague.
You say it doesn't connect but the scanner work, so that means it does connect?
Or do you mean you can not use the editor to pull the tune from the computer?
If that is the case you could have a few things going on. Something like an aftermarket alarm or aftermarket stereo is causing an issue.
first thing that comes to mind is you need to disconnect from the vehicle in the scanner before you can write with the editor.
Sorry I guess I should have explained better so I open editor and open my tune I changed something and wanted to write it and Editor says it can’t connect and scanner was not even open. So I opened scanner and it connects right away. So I disconnect scanner close it and pull editor back up and nothing it won’t connect. So I’m lost.
