e38 ecm - no ac press. signal voltage for wideband
2010 6.0-l96/6l90e swapped into 84 c20. im trying to log my aem wideband with hp tuners through the ac press. signal. i have the 5v wire from the wideband wired to the ac press. sig. pin 12 org/blk wire on the x1 connector. i have votlage there with the wideband powered up when backprobing with a voltmeter but in vcm scanner it always shows 0.00 volts. the truck had ac before the swap so im stumped as to why it wouldnt read the ac pressure signal. has anyone ever had this issue? im trying to tune the vve using afr error but without being able to log the wideband im hooped.
