1 Attachment(s)
Injection Mode Strategy & Stable Burn
I'm probably wasting my time, as with the previous questions I posted a few weeks ago, but here goes:
What is all this?
The "Enabled Modes" per the enabled chart don't match what the #'s in the Stable Burn or Strategy charts have in them. Per the modes (upper right), Homogeneous Lean is Off, is it not? At the bottom of the page it says Homogeneous Lean is Bit 1, but many of the cells in the Stable Burn and Stragety charts have a 1. Help me understand...
Then there's the 64 & 65 #'s in the charts. Wth are those? I can only "assume" they mean both bit 6 & bit 4 or 5 are active? Can two be active at the same time?
Bit 6 is Homogeneous Split Injection, per the description. Bit 4 is Stratified Cat heating, which is disabled per the Enabled Modes chart. So does a 64 just = 6 then?
65 would be a 6 & 5, but what is 5? It's not listed at the bottom. Not that it's enabled anyway.
I'm messing with it because my idle shifts into a different mode after 10-60 seconds, and that mode is leaner. I don't know how, why or what that mode is, only that it exists.
Playing with the #'s in the charts is not working out for me. It does do something, but not what I expect, or want, and so far only makes things worse. Worse being rough idle or an even leaner condition.
Like so many things here it's more of a cryptic puzzle with no explanation. Anyone know wth is going here, or how to decrypt the values?
Attachment 126575
