Billlllll!!!!
Billlllll!!!!
Hi, i havent used hp tuners at all, Tuned Saabs for many years doh.
How much can i change with this applycation?
What exacly do i need for tuning my 9-3 2,8 2006?
I'm sorry to bring up an ancient thread but figured I would have more luck here than making a new one. I have a 2006 Aero (2.8 E55) and I have been "playing with the tune" and can't seem to make any more boost than the factory 5 lbs. (I have boost gauge installed). It's my understanding that I have a TD04HL-17T turbo and I'm wondering if it is just maxed out from the factory? I even went so far as to unhook the wastegate controller and cap it off, I also disconnected the BOV at the same time and it did not make any more boost (disabled codes). Here are my questions, 1 is there a possibility that the bov or wastegate is letting off boost without the controllers? It doesn't sound like it. 2 Is it somehow regulating the boost by way of cam timing? The reason I ask is because I've noticed when it cold it only makes 2lbs of boost (still wastegate+bov unhooked) I also tried all the cam setting from a turbo X and it did not change the boost levels also felt a tad bit less responsive. This response led me to believe that the turbo is maxed out, however I do not believe that it could just hold 5 lbs of boost as there should be some variation of boost levels at different rpm/load so this has me confused. Would you be willing to explain how I can manipulate this tune? It is not nearly as straight forward as tuning GM v8's which is what i commonly do, but this is my daily driver and just want to make it more fun. Currently have "CAI" and high flow "test" down pipe, rear cat is intact. Any help would be much appreciated.
