2015 6L80e (Silverado 5.3L) Shifts not happening according to TCM tables
So I'm not 100% if I missed something here or not. The reason I'm looking into this is every WOT besides 1-2 the transmission is basically shifting as fast as possible (0.075s).
[ECM] 12050 - Fuel Cutoff RPM vs Gear: All set to 5900 RPM besides Neutral and Park @ 4000
[TCM] 15020 - WOT Shift RPM vs Shift - Normal: All set to 5800
[TCM] 15028 - Upshift Speed vs TPS vs. Shift - Normal:
10 10 10 11 12 14 16 18 21 24 27 32 35 36 36 36 36
15 15 15 17 20 23 26 30 35 40 46 51 55 58 59 59 59
22 22 22 25 29 35 40 46 54 62 70 78 85 89 93 95 95
[TCM] 15010 - WOT Shift Speed vs. Shift - Normal:
1->2: 35
2->3: 59
3->4: 95
2->1: 27
3->2: 51
4->3: 88
VSS Tire Revs Per (both): 634.99mi
1st gear shift WOT:
5908 RPM @ 39 MPH - 350ms shift
2nd gear shift WOT:
5751 RPM @ 65 MPH - 75ms shift
I can upload the files later on today if that helps.
