Mutha Thumpr Cams on 3v mustang
Well guys its been a long haul since I found this forum and started tuning but I feel like I have learned a ton the past couple months. Finally have that 12.5 AFR on WOT, and damn near perfect fuel trims, which is an amazing feeling after so much trial and error. Now, the next mod is something I've wanted to do for years. Installing cams. My set of Comp Cams Mutha Thumpr cams are coming in the mail tomorrow and I'm stoked. I'm also installing phaser limiters by comp cams so i don't touch valves. I've read up on it and there are a couple guys mentioning changing the max spark advance on multiple different tables to 18-20, and mention some other stuff to dial in the idle. I want to hear what some of you have done for your 3v to have your mutha thumpr cams running titties and sounding good. Is there anything that you guys would recommend changing for power improvements and drivability?
