2 Attachment(s)
Need help with 2017 Silverado 6.2l Pulling timing from Tq mgt from a stop/slow roll
So I am starting to get real frustrated with this timing pull. If I'm just driving and come to a stop and then start to take off again with 50% throttle and under at times tq mgt will pull a shit load of timing. I think I know where it is pulling it from, the minimum spark tab 12701 under advance. I have certain areas put to 0 to test this theory. What I don't understand is why is it pulling timing in the first place. In the log its not spinning tires. What am I missing here? Traction control turned off makes no difference. The only time it wont pull any timing is when Traction control and stability control are off together but it only keeps off stability control until it hits 35mph then automatically turns it back on. :banghead::banghead:
I have attached my tune file as well as the latest run I just did. At the end of the drive is where it is pulling timing down to 0 Degrees. time stamp 08:57.663 and on.
Any help or thoughts are appreciated. Thanks in advance.
Ryan
