Hey guys does anyone know that code for ford 39# injectors ? ... any info would help
thanks
thanks
Someone gave me this but i dont think that its right
Flow rate low 39.01294 lb/hr
Flow rate high 32.24041 lb/hr
breakpoint 0.00001400
pw minium 0.40054 msec
oh that helps alot ... information I have is all wrong !
how about the FNPW_BKCOMP settings ... do i need to do this ? the psi chart doesnt match with the one on the hpt ?
I used all the new data for the 39# injectors and after the update the truck runs super lean at idle ... did i miss out on something
Attachment 54025
sorry this the injector number I got off the injector 2r3v-b5a ... maybe the data sheet i got is not right for this ?
Make sure your table values are going out to the right decimal place. Most of the spec tables are at 3-4 decimal places. Also, your pressure scale on the Injector Offset Multiplier table is incorrect. Aside from that, the values look fine. Time to adjust MAF settings.
ok ... so i corrected all the values properly to the decimal point.. after this i need to adjust the mass air flow ?
Hi, i have this injector with fuel pressure axis 60/65/70/80/127PSI fuel regulator is set to 65psi how determinate or calcul the injector breakpoint? thanks
someone asked the same thing on another forum today
http://forum.efidynotuning.com/viewt...hp?f=51&t=3813
