This is an update to my first post. I got the car moving but now for some reason it will not move past 1st gear??? and I cant manually stick shift or paddle shift it out?
Attachment 95884 Attachment 95885
A lot of stuff changed in trans tune, suggest you return to stock and start from there.
any luck?
Transmission is blown and is getting replaced. This has been a real blow to my confidence to tune :/ I went back to stock setting but I'm pretty sure the damage was done as it was slipping in every gear until the infamous clunk and the car shutdown. So I'm getting it fixed this upcoming week and then getting it dyno'ed at a shop to get it properly tuned up....
Sorry to hear that. One thing I will not mess with is the vitals in trans tune. Troy set up tune with his valve body and I just tweek little things. Upgrade all the clutches and look into Ding's Racing valve body and tune.
https://www.lxforums.com/board/trans...alve-body.html
https://www.facebook.com/pg/Dingscompletecarcare/posts/
