need help my g8 l76 6l80 will not shift at WOT I hit rev limiter at 6400 rpm but it is supposed to shift at 6000 Attachment 96941 Attachment 96942
Lower the shift mph a few to see if that works.
Because you have the part throttle 100% for 2nd gear at 62mph and the full throttle shift speed table at 58mph. Those should have matching values. You are tagging the limiter at 60-61mph from what it looks like.
Side thing here, you should add knock retard, cylinder airmass and your injector information to future logs, they are really helpful things to know.
I lowered shift mph down to around 54 and it?s still doing it
I do have 3.45 gears but have changed that under the speedometer tab
Go to transmission section, scroll down, get Bluecat software. Input values and copy paste to tune
I downloaded it and put my information in but figure out where to input that information to go tuners
I got Bluecat figured out and it fixed my issue thank you!
Yeah, that program is awesome
