The file you originally posted worked perfect. Thanks. :$
Sorry for not posting back... I couldn't find the thread with HPT's search.
if you can find a 60e file you can run that and a relay if no 80e seg is available
*** Didn't really read through and see you had figured it out already.
Dave I always revert the 03's back to a 12212156 OS and copy the 2003 VIN over. There are 2003 12212156 OS's out there which is why you are able to copy the VIN to a 12212156 OS file. Way easier for the options to segment swap to/from.
Actually, all 2003 corvette o/s are compatible with anything 12212156 is. Done a lot more research since first posting here as well as building a spreadsheet for compatibility for everything through 07. Hpt may not let you at this point but it can be done.
Anybody else got a way to do this? James or Dave? I'll be glad to pay for the help.
Thanks!
Kevin
