Transmission Calibration Help
Hi guys, can somebody please help, i have a problem with a LS2 transplant into a old chev pickup, has 6L80, its from a 2008 holden maloo hsv ute, pretty much a pontiac g8 setup for the americans, the VSS data comes on data bus from ABS in original vehicle, as none of that is there now, im trying to get the transmission to provide data to PCM so i can activate pin 57 to run a normal speedo.
the transmission ECU does calculate VSS, tho it is not equipped with a VSS sensor, only input and output speed internal sensors, has no repTos wire on trans pin 16 at the moment tho i can add if needs be.
The current calibrations are... PCM 12619078 E38 ECU
TCM 24243170 T43 ECU
would anybody know of a Transmission calibration i could flash that would allow this function.
