Is it possbile to do cut off on Tundra 2020?
The file have only one option for the rpm limiter.
I guess i can do it with tq tables but it will effect the Crouse control.
is there a way to do it?
Thank you in advance
Forgive my ignorance, but what is ?cutoff?? Not familiar with the term in this world.
Whatcha wanting it to do?
I am searching for the same as well but not only for the sound but to keep the engine in the power range when climbing sand hills. The idea is to disable the throttle cut and to enable fuel/ignition cut instead. I GM ecu you will find it under defco but in Tundra defco only shows the rev limiter RPM. Any one knows the trick?
Hi dear
Have you done this , would you please update about it?
I am still searching the Internet but no luck.
I tried to pull this info from some tuners here in dubai but they don't share their knowledge, at least to confirm if they are using HPtuners or not.
I am trying with other tuners also in Libya thru tiktok but no answers yet.
I will update you definitely.
