2014 cadillac 2.0t LTG crank/cam known good waveform and reluctors good position
Hi
I have 2014 Cadillac CTS 2.0t LTG and I am having P228c and P0171 also engine reduce power while cruising. Live data from the Autel MS909 desired rail press 3.0 MPA while actual rail press parameter is showing 0.5 MPA. Tried Active testing the high press pump regulator valve found the actual rail press does not follow the desired. When commanding 20 MPA Desired 10 MPA only. New high press pump from GM, new rail press sensor from GM and after all circuit checked following service information procedures and found nothing. I have tremendous doubt about slipped crankshaft or/and camshaft reluctors after I hooked my uspscope but I don`t have a known good crankshaft/camshafts correlation. Finlay, I re-timed the timing chain with two toothe retard of both camshaft from the manufacturer timing marks, then live data desired corrected and found matching actual but P0016&P0017 continuously triggered after retarding two teeth of the manufacturer timing marks. Please, if any one can help me with know good camshaft/crankshaft correlation waveform and if any one has crankshaft ad camshaft reluctor good position photo. I found GM TSB PIP3423P, N, M and L but not related to 2.0t LTG
