Unlocker Timed Out
As title, unable to write a file to BA Turbo. Seems to have been an issue since updating software. Was able to flash once with write entire but no luck since.
Seems to take a long time once Write is hit to come up with "Turn off ignition wait 3 seconds"
Anyone else having this problem?
what version did you update from and to?
Didn't take note unfortunately. Was first time I had been instructed to disable PO605
what ignition cycle are you doing?
I never do 3 seconds, in ba i'll go off/on with the key quickly then wait maybe 2sec. bf and fg can bf cycled off/on and hit write without waiting at all.
I find doing the quick off/on with the key was what gave me consistent success.
Tried all of the above until the program crashed. It takes about 10 seconds for it to request the key cycle so I believe it has already timed out by that point. Behind the request screen you see it say writing just after it appears...
just try rolling back to the previous version or uninstall/reinstall the version you're using
