Hello, I was wondering if I could get some help as my researching is coming up empty.
I just loaded up the stock tune from my 2008 Sport Trac and looked at the transmission settings. I did some research and I am not seeing your typical settings like you would for other cars. It pulled up the 6R80 transmission in my tune (that took forever to download). I pulled up a 2008 Mustang Auto Stock Tune to compare and it looked very similar to mine, but had its differences. I was looking to get firmer shifts and raise the shift points, but this thing is all over the place. I can see where I can raise the MAX RPM, but that's total before limp mode. I do see a Shift Pressures tab, and it has Base Pressure....though it shows things like each gear and a Torque FT/Engine speed graph for each. The numbers just show 5.20, 9.40 and 17.30. No clue what that means. Can anyone offer any tips on what I should be looking to modify? Maybe a primer for where I learn what the settings do? It has all these torque converter options that I really do not want to mess with. I just want help with the lazy stock shifts. Really wish the Repository was not cleaned out so I could look at a modified transmission strategy from my year of vehicle. Thanks
Shift Scheduling Looks like this:
Attachment 116388
