okay so if i turn off fuel enrichment pedal by setting it to 0 percent. when will it use WOT lambda table?
Never.
I've never set PE pedal threshold to 0. But factory calibration has PE pedal percent set to 89% meaning the throttle percent needs to be 89% to Power Enrich. Then setting to 50% means the throttle must be 50% to go into PE. Wouldnt 0% make PE active at the lightest throttle? And to disable PE, threshold would need to be set 105% or a high value?
log fuel source
