3 Attachment(s)
NAG1 - Consistent limp mode on highway - 5.7 to 6.4 swap
I recently got my 2011 5.7 pursuit to 6.4 swap together and found that the car will consistently go into limp mode on the freeway. If I take the car on the highway and within a mile it will go into limp mode. The car will stay locked in whatever gear it was in at the time. The car is so consistent at doing this that I can pretty much grantee that it will produce a limp mode condition in under a mile. The car appears to be fine on the street. Under load I haven't seen this issue. It only when cruising casually on the freeway.
I thought that my tune may have been off so I used the stock 5.7 trans tune to see if I could get the same result and I did. Within a mile the car went into limp mode again. I logged the car during this process to see if we could glean any useful information.
I also have codes P0743 - TCC Solenoid Circuit, U0100 - Lost communication with ECM/PCM, and U110B - Lost Engine Coolant Message. When this happens my speedo dies and in the VCM scanner I could see that my speed was pegged to 319.
What could be causing this issue? Why is it so replicable. I can't tell if my tune is off or if the valve body is bad. My initial thought was that the TCM received data values that it didn't like and resorted to limp mode.
Any help would be much appreciated.
Here are the aforementioned files.
Tune: Attachment 127473
Log of limp mode: Attachment 127474
log of limp mode with stock 5.7 trans tune: Attachment 127475
