Howdy,
Are the following parameters supported by the Scanner for the L67 PCM?
Oil Pressure
IAC counts
System Voltage
MAF Hz
Idle Cmd rpm
I've tried adding them to the log traces but none of them showed up when I started scanning.
Thanks,
Howdy,
Oil Pressure
IAC counts
System Voltage
MAF Hz
Idle Cmd rpm
Thanks,
maf hz yes, I don't recall seeing the others on my own personal GTP.
Interesting on the IAC stuff since they show up in the PCM controls section of the scanner (the one where you do a case learn and such) but nothing on the logger. System voltage shows up on the cable diagnostics but we can't log it?
Just trying to get as many things as I can that relate to problems I'm having in the log.
Thanks,
On one of my 2002 tune files, IAC counts are there (and I believe cmd idle as well) - but on another of them, these items are not there. Both tunes work on the same PCM when doing a write entire. Sorry, cannot recall the OSIDs at the moment.
I have system voltage on the main display and as well as IAC position (same as IAC counts?).
I have the same issue the MAf hz will not log. i added it and it just show 0
