Dodge Viper Gen4 & Gen5 (Venom) Support
Ok, We've released the Gen4 & Gen5 Venom tuning.
Currently I'm only posting the information here because there is a caveat. Be sure to read this whole post before you decide to try and tune your Gen4 or Gen5 Viper.
1) The stock calibration cannot be read out.
- Because of this, we provide you with our modified operating system that includes some scanning enhancements.
- This also adds read capability to the Gen4 calibration (Not available in Gen5).
2) When you read your PCM for the first time, when you write back to your PCM, you WILL LOSE any tune/changes that may exist on your PCM. You will be starting from scratch with our custom operating system.
- If you have an aftermarket PCM, you're better off selling that and buying a stocker and starting from scratch.
- This does not apply if you're tuning a Gen4 that already has our custom OS in it: (05029932H0, ends in H0)
3) ** VERY IMPORTANT ** After you write your PCM for the first time, you MUST perform a throttle relearn. I have not had the time to implement this in VCM Scanner yet. Currently, you MUST use the factory tool to perform this function. Without it, your vehicle will not work.
When I have added the throttle relearn functionality to the software I will update this thread. Until then, unless you have the factory tools you should not be trying to tune your car.
** NOTES **
1) Anyone can read their Gen4 & Gen5 Viper to browse the tuning capabilities without worrying about having to use the factory tool to perform a throttle relearn. The throttle relearn is only needed on the first write.
Enjoy.
