2 Attachment(s)
Twin Turbo z06 Lean WOT. Fuel Pump? or Tune? log/tune attached
First off thank you to the community, you have been helping me on this same car for over 2 years, bolt ons first, then custom cam, and now I am full twin turbo.
The car is running fine, starts, cruises etc... all great, I can not get AFR corrected when hammering the throttle.
MODS:
Speed density
Twin turbo on3
Cam 228/248
85# snake eater injectors
stage 1 snow brothers methanol(powered by hobbs switch 1 PSI)
Boost a pump 18v (Powered by Hobbs switch 1 psi)(Stock z06 Pump)
bkr7e spark plugs .28 gap(tried tr6IX iridium gapped 40, same result, very lean on WOT)
everything else is a small add on and should not heavily affect the afr
I see my injector flow ratedropping and figured it was from the boost(it could be that my fuel pump cant keep up), and I dont have a boost referenced regulator to compensate, but I am only pushing 3 lbs of boost, and thought i would be ok for now. I basically raped the VE tables and same result. I dont mind going back to MAF if that will help, I can even tune MAF only, which is probably my next attempt, but I wanted to hear from the experts, what do you think, is it transient fueling, maxxed out VE tables, Weak Fuel Pump etc... thank you in advance.
Attachment 98862
Attachment 98863
