Airflow -> Dynamic - Initial VE correction Factor table
Table 13426
The Initial VE airmass correction factor table is indexed to Baro and ECT.
I see little about this table in my searches. After constantly messing with Idle airflow (the Startup Airflow and MAF SS airflow tables under the Idle tab), I consistently read high in startup airflow values and actual measured airflow, even with VVE pretty well dialed in when hot.
Anyone have experience with how this table works, aside from a straight adjustment relative to Baro and ECT? I suspect it may be why my airflow values are really high on startup, which might explain why my startup is idling high and then timing is pulled to reduce engine RPM at idle?
In stock form, it looks like it should be multiplying VE values by 1.15 to 1.2 in colder temps, ie an adjustment to the "hot" VVE values?
