2013 ZF8HP tuning.
I have a 2013 Charger SXT AWD with the ZF8HP transmission and wanted to try and do some transmission tuning. I have read the sticky on Getting To Know Your ZF TCM and have a better idea of tuning shift points. What I am having trouble with is knowing which Acceleration Factor and Aggression table to use. I see where others have been able to log these in the scanner. I do not have these listed as being able to scan for my car. I was running version 4.8.7 Scanner and then tried BETA 4.9.180, re-scanned for available PIDs and still does not show those tables. I am able to log other parameters for the transmission. Am I missing something or is it possible that mine just doesn't have those PIDs?:shrug:
Are you looking for channel Shift ID?
Yes, if I understand correctly this should show me which table is being used to shift at that time.
They'll have to add it for you if it's not there.
OK, thanks for the help. I'll submit a ticket.
