I used Track Addict this weekend and was not able to find a way to control both Wifi devices. I ended up just disabling Wifi on the GoPro and manually starting that recording.
Is there a way to control both from the Track Addict App?
Unfortunately the smartphone is only able to connect to one WiFi network at a time, so when the OBD interface being used is WiFi-based, this effectively limits the TrackAddict app to using one or the other. In this case, most people would use WiFi for the OBD connection, then control the GoPro manually.
Bluetooth OBD devices can be a solution for this on the Android side, but our iOS options are limited due to platform restrictions (only GoPoint BT1 / BT1A is supported for Bluetooth).
Thanks, that's what I assumed and that's how I did handle track day, was manually starting the GoPro. In RaceRender I was able to tell it when to start showing the data collected from TrackAddict.
Both are awesome tools! I just need to use them more to get more familiar with all the features.
