Any one make any progress with getting these to work on the 411 ecu?
Get x-link throttle module adapter for specific OEM throttle model (LS3 gold or silver plate , L92 or LS2) if you interested. I had one before with L92 throttle then I tried it with LS3 gold plate , had a lot of issues specially with random REDUCE engine power . Now I am on 78 stock throttle .
i did not think the x link would work as it has 8 pin plug and the c5 has a 6 and 2.
I got a gold blade to work not real long ago... I think it was even a 98 C5!! Set your Throttle Max Rotation % vs. Pedal to be 96.80 at every cell that currently reads 100%. It will open all the way without pushing "too far" and setting REP.
Will try as well. I'm using a sneakeater 102
I'm running the latest xlink for in LS3 goldblade on my P59
Changed my ETC Area Scalar from .0164 (stock) to .0208. Your setting may vary, do some google searchers for this setting. Putting in .0208 for a starting point will probably let the car idle at least, mine wouldn't stay running at .0164.
