Using a GM computer as basic methanol turbo controller
I am building a SBC old school with twin turbos to run on methanol for drag racing. Can I remove a wiring loom and computer from a doner PU that can be programmed to run without inputs for trans and other missing components. I will have wide band O2, mat, ct, tps, map, tach. Also larger injectors and high flow fuel pump. Can the stock computer self learn a fuel map? Will it work as a speed density program as well? What years of computer would be a good choice to adapt. I have never used HP Tuner before but have used many other software programs and worked doing computer system diagnostics for the last 20+ years. Please share your expert knowledge.
