How does everyone go with the timing side of things? I have the AFR pretty good and have no KR at the moment. Do i slowly add timing until i get KR and back it off? Also is it the borderline Knock table i make changes to?
I use the Plex knock monitor for determine the boderline.
Attachment 83396 Attachment 83397 Attachment 83396
Depends. You need to see what tables are being used when adding removing timing. For instance on a wot pull if your using table 0 70perce t and table 1 30% you have to do the math and add or remove timing on each table. Log map point weights so you can know what table is the one you will be working on
Post up a recent log file.
You should be getting some KR. Maybe your aren't logging the right parameter. Or are your knock sensors disabled?
I've seen KR activity on a stock tune with e85 even on low boost.
You should be seeing some kind of knock retard, especially if you are running 98.
What fuel are you running?
