Guys, Any help would be appreciated...
STFTs in VCM scanner in channels reads different then in the chart display. Which is correct? Or is this some type of weird resolution thing?
You are logging 49 PIDs. Get rid of the Ave. stft pids too. Look at the Polling interval, poor resolution.
To fix it keep it below 25 PIDs for a P01 ECU for best results. It just doesn't have the bandwidth. Use chart data.
[QUOTE=Hondaeater;615662]You are logging 49 PIDs. Get rid of the Ave. stft pids too. Look at the Polling interval, poor resolution.
Ok, will try....much appreciated
How did it work out?
I will let you know as soon as I get testing again...Plan to this weekend....Thank you!
sorry my dude, completly off the topic you are after but how did you log your oil pressure? thats a 411 i have a p59 would i be able to do that?
I have a PO1 and it was already a channel that was setup, but should be easy to add the channelQuote:
All better......Much appreciated
Attachment 101331
