Long term trims are usually in the 3-5% range, sometimes a few cells get out in the 10% range, and then randomly sometimes you will see a short term trim go out to like 23% just for a second.
So I ended up removing the stock narrowband #2 sensor after the primary cat and putting my stock narrowband #1 in its place, then I put my wideband back in the bung right after the header collector merge. I am still trying to get someone to weld in an extra bung for me, but I am curious to see how this setup works out, so far if I remember correctly I think it already threw a code for the O2 feedback so the stock narrowband may not work after the cat.
So according to my wideband I am pretty close to stoich at idle (.95-1 lambda readings), but whats interesting is looking at the wideband feedback compared to the stock narrowband switching frequency. Keep in mind the bank 2 narrowband I moved after the cat in the second O2 sensor location (the one that just monitors catalyst efficency) and the wideband is now in its place. However it looks like the switching may be out of phase and when the bank indicates lean it is rich. I am assuming the bank 2 sensor is switching at a lower frequency as compared to the bank 1 because I moved it after the cat maybe? I realize this is not the way to do it, I just don't have a choice until I can find someone to put in a bung for me, or maybe just go ahead and buy headers with an extra bung in them.
Attachment 97065
And I got your message SILV thanks a lot, here is my tune file.
Attachment 97066
