2 Attachment(s)
I need help with a swap V6 to V8 . Convert a P59 to run a V8 originally ran a 4.3L V6
Guys I need some help. I have a 2003 Blazer that originally came with a 4.3L V6 and I'm swapping a 6.0 LQ4 in it. My plan is to reuse the original ECM (P59) and convert it to run the LQ4.
All I did was find a V8 file with the same operating system and used the segment swapper to swap in the engine and engine diagnostics from the V8 file . I also removed the VAST and did a "Write Entire" when I flashed it.
I tried to turn to truck but it's not turning on. I can hear the fuel pump prime with the key on but after I crank the truck the fuel pump stops working.
Is there something else I'm missing when updating a P59 to run a V8 engine when it was originally used to run a V6?
I'm including the original file and the file I modified.
ThanksAttachment 107554Attachment 107555
