FPFD325 Flex Logic
Hey guys and gals, I've enabled Flex Logic re-polled PID's, Started loggin content pid and fill up with 11 gal of E90. Content shows 0% but ECU has learned the content. AFR is roughly 11.0 and Lambda 1 with scanner. Which is where i expect to see this with 3 gal of 93 left in the tank. in my tune ive adjusted the flex tables. i used a example found here to do so. Hopefully what i used is correct. Log file was too large for the forum to upload unfortunate. I can pull one later if needed.
Attachment 100840
Anything from anyone? Ive reset KAM a few times did a comparison to some other files found in some threads and seems like I should be getting a content change. My PID stays at 0.0% even though Lambda changes accordingly. Ive refilled on E90 about half a dozen times with no change. FPFD325 is a 2014 Manuel 5.0 strat btw
Sensors are working perfectly fuel trims are +- 2 when running 93 and on e90 within 10.
Have you sent in a ticket to support?
No I have not. Wasnt sure if that was needed.
try that, the strategy may need an update.
