So gurus please explain when it is it that i would start to change the "Map at Zero" table. Let's just say i have my injectors scaled right and i have been using an lc-2 and logging.
Ive been changing the MAP per Airmass High Res table and been having good results but as i look at the same rpm vs cam angle i see the afr change quite a bit. Is this when i start using the map at zero and how does it work??
