Im still learning on tuning so far im doing alright but havimg problems on how to use the tow haul option any help will be appreciated
What do you mean by that?
What are you trying to achieve with tow/haul?
On mine it is the shift scheduling under "Pattern A" when in tow/haul, yours could be different. "Normal" should be when not in tow/haul. Log the Trans Shift Mode and activate the tow/haul on and off so you can confirm what pattern it is called in your cal.
Run it through the Bluecat Trans tool and use 5200 for Desired shift rpm
https://forum.hptuners.com/showthrea...Table-Software
https://www.youtube.com/watch?v=X8vi7A7RGEs
