4 Attachment(s)
Launch timing control using KR
Started this thread in the lounge - thinking it might be more appropriate in here. Basically I'm feeding the knock sensor inputs with a pulse generator in order to cut timing on the line after the turbo has spooled.
I've gotten the circuit working in neutral but can't seem to get it to work under load. Hoping some big guns can chime in. Here are some pics of the issue:
Attachment 95007
Off screen I'm turning the circuit off which is causing the KR to decay - this will be run in parallel with my t-brake.
Attachment 95008
I'm on the t-brake in this pic, see how the KR doesn't increase once it sees engine load?
Car is a '65 Tempest 4.8 s475 th400 transbrake. Thing lanuches TOO hard, and so I've heard the trick is letting the turbo reach critical mass but cut timing.
I've attached a tune and scan as well.
