1 Attachment(s)
Please check tune for Idle / slow speed issue
Tune shop got file corrected and now engine runs pretty good. Only real issue is with low rpm / idle engine dies kind of randomly.
to re fresh
Its a LQ9 stuffed into a 95 Impala.
Bottom end stock
706 worked heads about 11:1 CR
BTR Stage 3 Ca.m
52cc injectors, good ones :o
Mid length headers
built 4l60E , 3100 Stall
3.73
Stock TB for the LQ9 which is out of a 2004 Escalade
CP wiring harness, DBW parts stock from the Caddy.
The engine will run good above 1000, and with the cam below 1000 pretty lumpy. Starts up and Idles fine hot or cold. Blip the throttle and 3 outa 5 times engine dies while in park, 4 out 5 when in drive. Worst case is when coming to a slow turn engine may die and no PS.
Can I get a review of the attached tune file ?Attachment 93834
