2 Attachment(s)
OS compatibility 6l80e limp mode
I got an engine and transmition from a 2014 Yukon Denali wreck with 62,000 miles in them to swap in my firebird. Removed VVT, DOD and installed a ls3 crate engine intake/throttle body and injectors. Had a friend of a friend modify my harness and remove vats and never could get it to fire, and HPtuners stopped connecting(think the harness fried the ecm). So got a new harness from Bpautomotive and a new ecm from ebay from a 2009 Corvette and bought HPtuners to try and do everything myself. :doh:
Now it runs and drives but it doesn't shift. Driving it down the road the scanner shows it shifts through the gears but it doesn't.:banghead:
I'm thinking the OS for the ECM and TCM aren't compatible. Can I install a 2009 corvette OS into the 2014 6l80 TCM or am i missing something else.
E38 OS is 12628990 and T43 OS is 24265260
Also getting P0700 and U0100 DTC's
Tried searching the forums but could find a definitive answer and don't want to brick anything. Need help!!!!!!
Thank You.
Attachment 93534Attachment 93535
