Im new to hp tuner im in my shift pressure setting how do I firm up my shifts wot
2015 mustang gt automatic 3.15 gears
Try Trans->Shift Pressures->Upshift and for Oncoming Clutch section, on 1A-2M, 1M-2M, 2M-3M, 3M-4M change those tables. The entire column for 5500 and 6000 RPM you can increase the entire column to 128 if you want. Play around with 100 or whatever and find what works best for you. That's a good place to start.
1A-2M is for shifting under 3 or 4 mph if i remember correctly. Therefore it is of no use when looking to firm up WOT shifting because you'd be past that MPH and that table will not be in use. So unless you want firmer low speed shifting from first to second gear, 1m-2m is the one to change along with the other xM-xM gears.
Thanks everyone that helped a lot
