Originally Posted by
Saxxon68
Ok I sent a PM to 4 members. Now this material is washed after being cut, but not pressure washed. (the plastic is pressure washed) The foil gauge is .001 inches and cells are cut to partial cells to make circles. Since this is running after the air cleaner, aren't you worried about foreign material entering the engine? Like a loose piece of aluminum or dust? Sounds like your in and out of your intakes all the time so I was just wondering.
Are you guys sure about 100mm inside dia.? The photo the cells look a little crushed in to get it to fit. Anyone have one they can measure the inside dia. with calipers? It is best to fit tight, but not to crush cells on install.
