step by step turbo hemi tuning let learn and share
Im looking to start a thread form start to finish turbo set up and tuning
ok my set up is a 5.7 hemi
2 degree colder plugs
2 bar srt4 MAP
8 SRT4 injectors
walbro 450 mounted in stock basket with a return running threw a boost referenced regulator I used a one fuel rail from a car and one from a durango so there was a feed on each side one side i used for a return the other for feed
holset turbo (soon to be changed to chinesse with a better match A/F) under car mount turbowerxs oil pump to return the oil to a bung in the oil pan feed supplied by a tee in the oil sending unit
