1 Attachment(s)
Attachment 98557
Datalogging a CVAE7BZ and i'm having the same drop out issues, but no surprises there. Would be great to get a fix to help resolve issues i'm having with the car or tune.
- 'Fuel pump Commanded DC' is showing ~15% whereas 'Actual Fuel Pump DC' is showing 0%. Assume this is also a logging error?
- Spark source is showing Base / MBT, however spark advance doesn't exceed 0 degrees. The exhaust decel note confirms the timing! Not sure what the issue is here, assume its a tune issue.
- The idle adapt is pegged at 3.0 g/sec. Adding Idle air isn't doing anything, unplugging the ISC valve doesn't affect the car nor change the logged ISC duty cycle. Not sure if this is a tune issue or mechanical as there are no fault codes and the ISC is getting and returning voltage. I performed a base idle reset without improvement. Logged STFT shows -100% but FORscan shows it working correctly and the wideband shows Lambda 1.0 on both banks (in Closed Throttle mode and in Closed Loop fuel control).
