Results 1 to 5 of 5
Thread: Pro Link cable to PLX wideband
    Oct 2022
    2
    Question Pro Link cable to PLX wideband
    Hi all,
    I'm trying to wire in the Pro Link cable to the PLX wideband sensor, I have found a few different ways online, but want to run it buy the brains trust first (I'm pretty new to this).
    Pro Link cable- Black wire (ground)- to a good chassis ground point
    Red wire (analog 1)- to the 0-5v wideband output on the PLX
    Blue wire (analog 2)- Spare
    Orange wire (CAN high)- Spare
    Yellow wire (CAN low)- Spare
    PLX device- Power supply- Red wire (positive)- to the cigarette lighter positive feed, so it is live when ignition is on and uses the existing fuse
    - Analog output plug- Pin #1, 3.3VDC- Spare
    Pin #2, 0-1v Narrowband- Spare
    Pin #3, 0-5v Wideband- to red wire on Pro Link cable
    Pin #4, 8.0v- Spare
    Does this seem correct?
    Can I run/should I run the 2 ground wires (black wire on the pro link cable + black wire on the PLX power supply) to the same grounding point?
    Thank you for your time and help.
    Using:
    MPVI 2+ with Pro Link cable and pro feature set
    Nov 2022
    1
    I was just getting ready to post this same question.
    Jan 2023
    38
    Any solutions?
    Oct 2020
    7
    from reading I thought the black prolink wire is to go to the the ground on the sensor its self
    https://www.hptuners.com/pub/Pro_Link_v1.pdf
    Jan 2023
    1
    I also connected the Prolink black wire to a chassis ground. After rereading the instructions it appears it should be connected to the WB sensor ground. Has anyone connected the Prolink to PLX SM AFR successfully?
    How do I get output to gauge and chart to read AFR or Lambda? It currently reads voltage. Am I not understanding transform which appear to select voltage.
