i was wondering what exact perameters do i need on vcm scanner to correctly datalog and tune, i upgraded computers and forgot to save my old info 22-10-05 20-56-33.hpl
i posted a file for an idea of where im at so far
You can try mine if you want:
VCM Scanner.cfg
VCM Suite.cfg
These are the VCM Scanner.cfg & VCM Suite.cfg files. If you replace yours with these you should have all my settings. In my PC these files are loaded by default to "C:\Users\your user name\Documents\HP Tuners\Settings" so I assume the same for you?
I think the math functions should simply work, but if not I added them here:
Fuel Trim Avg Math.MathParameter.xml
Boost Math.MathParameter.xml
HP.MathParameter.xml
Knock Retard Avg.MathParameter.xml
MAP psig.MathParameter.xml
'16 E550 Coupe RWD - C207.373 / M278.922 / MED17.7.3 / 722.909
I wouldn't let me post all of them in one post so here's the individual items if you wanted to go that route. The Channels file is the all important left side of the screen with all the things you want to scan. The Layout is the overall layout, which is how big of a space and where each section takes on the screen. I also added my "Properties" files which are my color settings for each item.
Channels.Channels.xml
Charts.Charts.xml
Gauges.Gauges.xml
Graphs.Graphs.xml
Layout.Layout.xml
Properties.ChannelDisplay.xml
Properties.ChartDisplay.xml
Properties.GaugeDisplay.xml
Properties.GraphDisplay.xml
Since out cars are more or less the same I assume all the channels will work for you. If not it'll be pretty easy to adjust it compared to starting from scratch
