Originally Posted by
Tunercharged
If the engine is not tuned to make more power via more advanced timing than stock, it probably will not bring in more air with a bigger intake tube/ MAF since that is not a stock restriction. Increasing timing, and adjusting fueling, to the point where it doesn?t make more power will tell you if that setup will soon require more intake tube/MAF size. Other things can restrict flow such as exhaust, cam, valve size. Tune for what setup will allow then find restrictions to eliminate for more power if wanted. For WOT add fuel on PE table.
