Results 1 to 11 of 11
Thread: Missing pids 2001 lq4
    Jan 2021
    6
    Hp isn't displaying alot of my pids from my engine I tried deleting my vehicle file from folder and still nothing but on my tdn it shows water temp and rpm. Thanks in advance
    7,699
    Have you tried turning it off and back on again?
    Jan 2021
    6
    Yeah I reset laptop I also deleted hptuners and reinstalled it and nothing when I plug it up to my 2010 gmc it shows everything
    Nov 2017
    1,500
    Repoll for parameters?
    Jan 2021
    6
    All those tabs are grayed out I cant do anything when I unplug it all the pids are there but once I connect vehicle they all go away
    Jan 2021
    6
    Should I mention that it's a Chinese harness but I checked all wiring and they are good and they are all factory original sensors
    Nov 2017
    1,500
    More info on what your project is might be helpful.
    Jan 2021
    6
    It's a 2001 untuned lq4 truck norris cam with factory cpu with stock 4l80e
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    IF YOUR PIDS ARE SETUP FOR A LATER VEHICLE, ITS LIKELY LOOKING FOR THE WRONG PIDS. YOU MAY HAVE TO MANUALLY RESELCT THE PIDS AND TRY AGAIN. oNLY TIME IVE SEEN THIS IS WHEN INCORRECT PIDS WERE CHOSEN
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Jan 2021
    6
    This is what I'm getting
    13,574
    If you click connect to vehicle at the top left and then click "vehicle" and everything is still greyed out, there has to be something wrong within the software.
