Results 1 to 3 of 3
Thread: 2003 cm845
    Dec 2020
    9
    2003 cm845
    Truck was tuned with an Edge programmer of some sort.
    Couldn't return it to stock.
    "Read" the stock file, modified the stock file, and now when I flash I get "Controller Unlocker: Timed Out". I did license the controller.
    Truck won't start and my SnapOn Solus Edge cannot connect to the ECM.
    What do I need to do?
    Dec 2020
    9
    Well, I decided to try the old trick of disconnecting the batteries. Let the truck sit for about 30 minutes with the ground wires off and then I was able to flash the ECM.
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    208
    Engine start now??
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
