2021 jeep grand cherokee 5.7 procharged jeep5.7-upload pop bang-10.18.2022.hpt
I included my latest tune i did a couple hours ago. I am getting bucking and surging.. please help
Thank You
Thank You
Thank you for the response.. I will take that into consideration.
Meanwhile I have a good running tune that I wanted to adjust to get some bangs and pops to make me smile.
I?m sorry you have not been satisfied with the product.
I have no problem with ? donations ? for a tuner to take what I have and make it want I want.
04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
G3 Hemi Videos
https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
Thank you , I will look for it now
Looks like I forgot a table that needed to match.. from what I gather the Part throttle base, MBT and Minimum Spark tables need to have the same change made in order for it to work.. I could be wrong though
I wound up figuring it out, I had to match 3 tables of the timing I wanted and bingo it worked
Good info there.
you have to log your decel spark and then retard timing in those areas on all spark tables it seems, if you search for "burble tune" i did find more info and videos on it.
My Avalanche with single inlet/dual outlet Flowmaster muffler, burbles and crackles on deacceleration, but only on the freeway at higher RPM... on a STOCK tune.
Crackle and popping otherwise is done by changing the fuel ratio to run super rich. All that unburned fuel can't be good for the cats, let alone other engine components.
