Hey tuning gurus - NGC4 PCM, 392 Hemi here,
I'm seeing some pretty consistent bank-to-bank fuel trim differences - even when varying the cam position - and have been trying to tune them out. Here's what I've tried:
- Artificial Neural Network - Mult Bank to Bank: This one definitely works. In my setup, raising the multiplier above 1.000 will (comparing Bank 1 to Bank 2) make Bank 1 leaner; below 1.000 will make Bank 1 richer. Maybe the better way to say it is that the multiplier is applied to Bank 2, so when the multiplier is set to, say, 1.05, 5% more fuel is added to bank 2. The problem with this approach is that it appears to apply the multiplier everywhere (all engine RPM, all loads). Most of my fuel trim differences seem to vary mostly by RPM and somewhat by load (as seen by pressure ratio).
- Fuel - Open Loop / Base - Mass to be Delivered - RPM Mult Cyl#[1-8] - So far, I've tried adjusting the RPM Multipliers by a few percent. For bank-to-bank, I've simply modified all cylinders of a bank by changing all four cylinder tables by the same amount. I'm not sure if the changes are having any effect on fuel trims.
- Fuel - Open Loop / Base - Mass to be Delivered - Fuel Mass Mult Cyl#[1-8] - I have NOT tried messing with these tables because they allow adjustments according to "Mass Airflow" (anyone know what channel that might be for a Hemi with no direct airflow sensor?). I'm trying to go after the RPM-related differences before tinkering with these tables.
- Speed Density - Volumetric Efficiency - VE Bank 1, VE Bank 2: I know that tuning these tables independently will work, but I'm trying to get it done with the ANN and VVT enabled, so my VE tables are disabled.
That's all the levers that I know of to accomplish bank-to-bank tuning. Any of you experts know any tips or other ways to git-r-done? Thanks!
