so you want to go super lean at maximum boost? i wouldnt exactly call it the greatest solution...
not lean no fuel like a fuel shutoff rpm. but with boost. i say this caus ei have 310cc injectors and my injector duty cycle would be over the max with that boost so it could run lean anyway jsut trying to save my block in every way possible. if its a bad idea cause it will give me half the fuel instead of none then i understand.
2006 SS Cobalt SC
Stage 2 ZZP Cams
Headers, 3.0" Full ZZP Exhaust
60lb inj. Intake.
2.8 Pulley
72# Lb. Supertech Springs
LNF Ext Valves and lashers
Cobre H/E, option B.
Torque Damper
HPTuned.
Bitchin'.
